Edit the meeting invite for CRC | Community
  • January 20, 2022
  • 0 views
Hi!
We're about to replace the SIP/H323 gateway address, and need to update the meeting invite.
Where do I find and edit the parameters below?
Join by SIP (Cisco/Tandberg, Poly/Polycom etc.)
${number?c}@${h323Gateway[0]}
<#if ((h323Gateway?size) > 1)>
${number?c}@${h323Gateway[1]}
</#if>
</#if>
Thanks,
Brgds Martin
    jon
    @mast
    Here is how you would change the email branding for meeting invites.  You can find them under Meeting -> 'Meeting Invite Email'
    https://support.zoom.us/hc/en-us/articles/213735683-Customizing-the-meeting-schedule-email-template
    I hope my response has given your question a solution or a workaround. If so, don’t forget to mark the reply as an accepted solution!
    mastAuthor
    Hi Jon,
    Thank you for your reply.
    I’ve actually found this page, but it has this reference to h323Gateway[n], which is the issue.
    The invite will be read by a machine, expecting this parameter such as {{meeting_id}}, {{pin}} and so on, so I want to avoid replacing the variable with ieg clear text.
    So, is it possible to change the variables, or maybe Zoom need to help us in this case?
    Brgds Martin
