Custom questions during registration | Community
  • September 17, 2021
  • 0 views
When setting up questions and answers to select during registration can they only select 1 answer?  Is there a way to allow them to select multiple answers?
    vescamilla
    Hello mforge,
    You need to add a custom question, then you can choose to have "Multiple answers" as a question type.
    Hope this helps!
    If this answers your question, please click "Accept solution". Thank you!
    mforgeAuthor
    There is not an option to chose "Multiple Answers" as a question type
    vescamilla
    Hello mforge,
    My apologies, I thought your question was referring to Webinars. You are correct, no "Multiple answers" for custom questions in Meeting registrations. If you need them to supply multiple answers, you could choose "Short answer" and they can type in their answers.
    Hello - is there a way to enlarge or increase the character count for the short answer selection.  It doesn't seem to allow much text.  I would need at least 500 words?  Is this possible
    Bort
    No, in this case you should use the Long Answer question type.
    can I set up a custom question with a drop down vs radio button/ check boxes?  Check boxes elongates the form and we are trying to. standardize so we don't want free form text. Thank you for your guidance .
