creating shortcut for zoom on desktop
From some reason Im not able to create a shortcut for zoom on my desktop even after i press on the file "create shortcut". my operating system is windows 10 pro.
I will be grateful if someone can help.
@Alla2000 , You may just drag and drop the Application from the windows menu to blank portion of your desktop, it should automatically create a desktop shortcut.
