Cant connect to Zoom | Community
  • August 16, 2021
  • 16 replies
  • 168 views
I just got a new laptop recently, and after installing zoom, I realised I couldn't get past the log in page without a "You are unable to connect to Zoom. Please check your network connection and try again" pop up.
I then use my old laptop to try and find out if its really the connection issue . Low and behold, Zoom runs perfectly fine.
Any ideas on why this happens, and how to solve it?
    Best answer by CarlaA
    Hi everyone!
    On behalf of the Zoom Community team, we wanted to thank you all for the helpful contributions made on this topic. Because of the insightful feedback shared here on this community post, we were able to create a new support article that outlines how to troubleshoot the Zoom error on macOS: You are unable to connect to Zoom. We encourage you to visit and review this article to help guide you in your successful use of Zoom: https://support.zoom.us/hc/en-us/articles/6618841634957.
    Thank you!
    Moderator Zoom Community Team
    Nafi
    Community Champion | Partner
    August 17, 2021
    Hi
    You need to check wether there is antivirus/proxy/vpn/firewall on your new computer that maybe blocked you to access zoom.
    Also you always can test zoom meeting via https://zoom.us/test
    Hope it helps! please like and mark this as solution so whenever someone has the same question this content will help.
    Thanks for the Zoom Test meeting link Nafi, with that one I get
    "Unable to connect"
    "Check to make sure you're connected to a stable network that is not blocked by a firewall or proxy."
    Any luck? Mine is also stuck at "You are unable to connect to Zoom. Please check your network connection and try again".  things that have not helped:
    re-install zoom
    update Mac OS from 11.4 to 11.5.2
    turn off firewall
    turn off Malware Bytes
    Reboot (Mac M1 desktop)
    Also - I don't have a proxy - there is a great guide here on how to check that:
    https://support.grammarly.com/hc/en-us/articles/115000090431-How-can-I-tell-if-I-use-a-proxy-server-
    Anyone found a solution yet? I have been greeted with the same error ever since I updated Mac OS to Big Sur 11.5.2
    Zoom still works on my Imac but that is running Catalina so won't be updating that until this issue on my laptop is sorted.
    I have same issue too! In browser this is working and my phone app too, only mac have problem.... What is it? Zoom in mac worked early.....
    My chromebook can't connect to another zoom
    Same here.
    In browser this is working and my phone app too, but with my MacBook Air with Big Sur 11.5.2 not.
    Please help!
    If you have a Mac - I had this issue for ages and was unable to resolve it. I finally did a little more looking, and found this StackExchange post that suggested uninstalling Zoom by using their uninstall file instead of putting the Application in the trash.
    https://superuser.com/questions/1671647/zoom-on-macos-catalina-hangs-on-connecting-gets-error-unable...
    I did this by going to Applications -> right clicking on zoom.us -> Show package contents -> open Contents -> open Frameworks -> use the ZoomUninstaller file.
    After this, I reinstalled and it successfully worked.
    FYI @Erina @Javier1979 @None @AndreaKing @Ekinney in case any of you are still hitting this issue.
    This is the trick that worked for me. Nothing else did. Thanks!
    Thanks a lot @yuan-stanley . It works! 🙂
    If you're using a Windows computer, my solution was to go to the %appdata% folder and rename or delete the zoom folder.  Then open Zoom again.  It should recreate the folder and you should be good.
    Did not work for me. Any other suggestions?
    Have been fighting with this for weeks. After reading this thread, I *just* used the "for Macs with Apple Silicon chips, click here to download" because how the heck do I know I have a silicon chip?? And it worked! Crossed fingers ...
    As an IT professional, I was trying to help my wife with her Zoom (on windows)and of course, I broke it, resulting in the error messages folks are getting here.
    It's because I tried to sign her in with SSO, which she doesn't use. She always joins as a guest, and doesn't actually sign into Zoom. However, whenever she tried to click on a Zoom link, the Zoom app would try to go to the SSO URL that I initially tried.
    The fix was to sign her in with a working personal account, then sign out. It stopped prompting her for an SSO sign-on.
    Hope this helps other folks!
