Cannot connect to account and bug with "Unstable network, tap to reconnect"
Hello, I have problems with Zoom accounts and app on Android.
I gain notification "Unstable network, tap to reconnect" (All my relatives have this notification too). I decided to delate cache and data in phone settings and reinstall Zoom. After reinstalling problem was solved until I exited the application.
So when I reinstalled it again and had to log into my account, an error occurred. I received notification "Login failed. Failed to connect to Zoom".
Instead, I started entering the details of the second account and everything was fine until I was asked to enter a code from the mail. The first time I got it. However, he did not work. I received a notification that it has expired. Then I clicked on the button to be sent another code, but it did not arrive in my mailbox.
I reinstalled Zoom a third time. I started to enter the data of the second account and the message about failed login appeared on this account: "Login failed. Failed to connect to Zoom".
Error codes: Don't have
Device type: OS Android of different versions
Zoom version: 5.16.6 (17128)
