Can't delete my profile picture | Community
  • July 1, 2022
  • 8 replies
  • 8 views
I want zoom to display just my initials, like when you have no profile picture, but every time I got to the web settings and delete my profile picture, it keeps re-appearing in the next logon (it uses my Gmail account picture).
How can I prevent that?
    July 3, 2022
    Hey, @VeniceKing,
     Making changes to profile pictures and display names during a meeting using the Settings Profile option only makes a temporary change.
    To make a persistent/permanent (until you change it again!) change, go to your profile in the web:
    https://zoom.us/profile
    Tap on the profile picture and click the Delete button.
    Hi Ray. I do exactly that, I delete my profile picture but it keeps using the picture I have in my Google account.
    July 4, 2022
    Sorry, @VeniceKing, I’m assuming you’re signing into Zoom with Google?  I’ve never actually run into anyone that uses Google to sign in, and so my experience here is limited (non-existent is probably more accurate!).
     While I can’t find anything in the Zoom Support articles that says this is the case – I’d have to assume that if you’re logging in via Google, Zoom uses that for your profile picture. I can’t find anything that would indicate you can change that – except perhaps changing your signin to an email address.
    Take a look at this Zoom Support article on changing email addresses, which also has some info on logging in via Google and other services:
    https://support.zoom.us/hc/en-us/articles/201362563-Changing-the-email-associated-with-your-account
    Most of the help you get from the Zoom Community is from volunteers like me.  If you’d like to investigate further,
    you can submit a Support Ticket directly to Zoom Staff at:
    I will be testing this solution tomorrow, as I signed-in today without using the "Sign-in with Google" option, and deleted my profile picture made a couple edits to my profile information and saved the changes. I will see tomorrow if this method has solved the issue. If it does solve it, I will report the successful method right here in this forum thread. Until tomorrow, +peace+
    I tried everything including singing-in independently of "sign-in with Google" and still the picture persists! This is no solution.
    Yes, I use Google to sign in to Zoom. I'm going to try that, thanks.
    We need a fix for this. Stop pulling in my Google icon. I even removed the Zoom permission on Google and it is still doing it.
    Has anyone found a fix for this?
    I use Google to sign in to Zoom. I can log in and out of zoom.us in the browser and there are no issues with my profile pic changing. But if I somehow get signed up of the desktop app (v. 5.12.2 (9281)) and sign back in, my profile pic changes to my Google account image.
    I have already gone into zoom.us/profile multiple times to delete and re-upload the photo I want to use for Zoom (which is different from my Google account profile pic) and it continues to do change.
    This wasn't an issue until recently. I changed my Google profile pic about two weeks ago, but before that Zoom never used my Google pic.
    Kajuun
    By the way, this is still broken, over a year later (I avoid logging in to avoid this bug).
    If you use Google and have a picture on Google, you can temporarily delete it from Zoom, but if you EVER log back in to Zoom then your Google picture magically shows back up, and it shows up in all your meetings until you log in and delete it again while making sure to never log in again. (I speculate it is pulling it from Google, but I haven't tried changing my Google pic to see since I use a workaround, I never login again once deleted).
    Yeah, mine's broken too. Zoom won't let me replace the pic in my own dxxn account, and I don't even use google to log on. It would be ok, but I can't get a picture to show at all now when my video is off. Just shows my name. I've given up.
    Kajuun
    Nope, it is still not possible. I just double checked now, it simply comes right back the next time you login. My solution, I found a monogram of my initials as an image and uploaded it to Zoom. This gave Zoom something else to have since it simply will not let you go back to using your initials once you've let it know you have an image.
    That's what I did as well, but it shouldn't be doing this. This is a BUG!
    I have figured out a work around. I created both a 1x1 pixel .jpg file and a 4x4 pixel .png to use for my picture.  I'm sorry I cannot remember which one took, but I think it was the 1x1 .jpg. I simply made the pixels black and used it as my profile picture. This somehow shorts-out the display of the picture and instead it DEFAULTS TO YOUR INITIALS ONLY.
    If you try this and it doesn't work, then make a solid black 4x4 image file either .png or .jpg and try it again.
    ONE OF THESE WILL WORK
    Blessings,
    Br. Clif
