Bad Webcam quality on local screen | Community
  • September 9, 2021
  • 13 views
Hi can you help please? Strange problem. Local Webcam image corrupt when viewed on Zoom on local laptop. (See attached file - strange colours and fine vertical lines) Image looks fine on Zoom recording. Raw Camera looks fine on local laptop. - it's only bad via Zoom app. Any suggestions much appreciated.  Thanks
    Best answer by RevKim
    Thanks. It works when I select Touch up my appearance. Thanks for your help
    Rupert
    Try toggling on and off (or off and on) your "HD" and "Original Ratio" settings in your Camera settings in Zoom.
    See if that helps.
    Rupert
    RevKimAuthor
    Thanks Rupert. I'll give it a go.
    RevKimAuthorAnswer
