Audio issue, going from share screen computer audio back to normal audio | Community
  • January 13, 2022
  • 0 views
Hi, whenever I go from share screen/computer audio then stop share/normal audio the sound always drops out and everyone has to leave the room and come back in to fix the sound. I have this is lots of other people's zoom meetings also where they use this feature.  Can anyone help sort this?
Thanks Jen
    CarlaA
    Hi @jenEV ,  I know it has been a while since you initially posted, but I want to make sure you receive assistance. Are you still having this issue? If so, please try uninstalling/reinstalling the Zoom client.
    If you are using Windows, please follow the below instructions to reinstall the Zoom app;
    1) Close all Zoom windows
    2) Download clean Zoom here > https://assets.zoom.us/docs/msi-templates/CleanZoom.zip
    3) Try to install Zoom app from the download link at zoom.us/download. Download the first one from the list, Zoom Client for Meeting.
    4) Sign-in to Zoom app
    If you are using Macbook, please follow the below instructions to reinstall the Zoom app;
    1) Drag and drop the Zoom application icon to the Trash folder
    2) This action will uninstall the application
    I would also suggest all attendees update their Zoom client as well. Let me know if that helps!
    Moderator
    Zoom Community Team
    jenEVAuthor
    Thanks Carla, in the end everyone agreed they preferred the sound when I didn't switch to share screen/computer audio so now I just don't switch. As there wasn't just a dropping issue but also a hissing noise. In fact in certain meeting with certain clients I always experience a hissing sound, unless I hit mute and wait for it to go and then unmute again (and repeat every 5 mins or so).....
