Apr 19, 2025 4:06 PM UTC
Audio issue during a meeting
Recently, I have been facing an issue with my audio during a meeting with my mentor. He cannot hear me, but the audio input of my microphone during the meeting is fine. I can see the input level increase when I speak. What I've done so far is:
1) Checked if I selected the correct microphone channel.
2) Tried my pc, headset inputs and the issue still persists.
3) I've used also my iphone microphone and did not work.
4) I've joined the meeting from my iphone only instead desktop that I usually do and still not working.
5) Checked his settings also and they were ok!
* Bear in mind that I have a connected audio interface (Focusrite) but it worked fine in the past!
I cannot identify what is causing this issue! Please help!
Apr 21, 2025 2:24 PM UTC
Computer audio is very complicated. For any Focusrite interface be sure that the clock is set for 48K instead of 44.1K. Since you also tried an iphone and were not heard it is most likely on the other end. Make sure he runs the Zoom CHECK for his system and can hear the test signal on his speakers,
Markos9Author
Apr 21, 2025 6:12 PM UTC
Hey thanks for your input. I will give it a go with your suggestions!
