Zoom timer, pins and recording | Community
  • January 27, 2022
  • 1 view
I would like to share the zoom timer, pin one or two participants, and record only the participants I have pinned. I have tested this out and so far the Zoom Timer also appears in the recording. Is there a way to share the timer but not have it appear in the recording?
Thanks!
    Best answer by colegs
    @rchastain ,
    The recording will effectively record everything that is on the screen for the presenter, so unfortunately there is no way to share the timer and not have it captured in the recording.
    colegsAnswer
    @rchastain ,
    rchastainAuthor
    @colegs Thank you for responding! I was afraid that was the case and have moved on to an OBS timer.
    Thanks!
