Brand Vetting & Partial Upgrade: What Zoom Customers Need to Know | Community
iambobsat
  • January 30, 2026
  • 3 replies
  • 68 views
We’ve been getting a lot of questions lately around Brand Vetting and the “Partial Upgrade Available” label in Zoom SMS Campaigns — so we wanted to take a moment to clearly explain what these mean, why they matter, and how they affect your ability to use Zoom SMS.
If you’ve seen a “Not vetted” status or a Partial Upgrade Available tag and wondered what’s next, this post is for you.
What is Brand Vetting in Zoom?
Brand Vetting is a required verification process for Zoom customers who want to use SMS (10DLC) for business messaging.
It’s part of carrier compliance requirements and helps ensure that:
  • Your business is legitimate
  • You are authorized to represent the brand name you registered
  • SMS traffic sent through Zoom is trusted by mobile carriers
This process is especially important for A2P (Application-to-Person) messaging, which includes customer notifications, alerts, reminders, and support messages.
What is the Vetting Status for?
The Vetting Status (for example, Not vetted or Vetted) tells you whether your registered brand has completed carrier verification.
  • Not vetted
    Your brand is registered and active in Zoom, but it has not yet completed carrier vetting. Messaging may be limited in throughput or subject to stricter filtering.
  • Vetted
    Your brand has been reviewed and approved by carriers. This typically allows for higher message throughput, improved deliverability, and eligibility for advanced campaign options.
In short:
Brand vetting directly impacts how reliably and at what scale you can send SMS messages.
What Does “Partial Upgrade Available” Mean?
When you see Partial Upgrade Available on an SMS campaign, it means that:
  • Your campaign is currently active under default or lower-throughput settings
  • You may be eligible to upgrade certain campaign features without changing your entire Zoom account or plan
A partial upgrade can allow:
  • Higher messaging throughput
  • Expanded carrier support
  • Enhanced campaign capabilities
However, it’s important to note:
A partial upgrade does not bypass brand vetting requirements.
Carrier-regulated features still require an approved brand.
Note: This option is designed to support phased adoption, allowing customers to scale SMS usage as their needs grow.
How Brand Vetting and Partial Upgrades Work Together
Here’s the key takeaway many customers miss:
  • You can have an active SMS campaign while still not vetted
  • You may see Partial Upgrade Available, but upgrades may be limited until vetting is complete
  • Completing brand vetting helps unlock better performance, higher limits, and long-term scalability
Resources:
This is a great resource and will help a lot of users. Thanks for sharing!
crissyd
Very helpful, ​@iambobsat
New Member
March 17, 2026
I just got my SMS campaign approved, and now it’s urging me to “upgrade.” We only send around 100 messages per day on average, if that, even. Do I need to upgrade?
iambobsat
iambobsatAuthor
Hi Paul,
Thanks for reaching out.
What the “Upgrade” Option Means
  • The “Upgrade” message typically appears after your 10DLC campaign is approved and refers to moving from a standard (low‑volume) campaign to a higher‑tier or “enhanced throughput” campaign.
  • It’s an option offered through The Campaign Registry (TCR) — the carrier‑level system Zoom integrates with — to increase your daily message throughput (how many messages per second or per day you can send).
For Your Current Usage (≈100 Messages/Day)
  • You do NOT need to upgrade.
    Your existing standard 10DLC campaign easily supports that level of traffic.
  • The upgrade is intended for businesses that send thousands of messages per day or run marketing blasts that need faster throughput.
Standard vs. Upgraded Campaigns
Feature Standard / Low‑Volume Campaign (Default) Upgraded / High‑Volume Campaign
Daily Message Volume Designed for small‑scale use (under ~2,000–3,000 messages per day) Supports higher or unlimited daily volumes
Throughput (Speed) 1–3 messages per second (varies by carrier) 10+ messages per second, depending on tier
Approval Requirements Basic brand and campaign registration May require additional vetting and carrier review
Typical Cost No extra charge beyond standard SMS rates Additional monthly fee (varies, often $10–$50+ per campaign)
