My host key | Community
My host key
  • July 15, 2024
  • 117 views
Hello I need help please, when I login to my zoom account to figure out what is my host key it’s enabled and the edit button is grayed out. Can you help me please?
    @Luluabbass - Please make sure one of you account admins has not changed the security setting that allows you to update your host key.
    There seems to be no documentation on exactly where a host can find or set their own host key! There are many pages of settings, so one can benefit from detailed help.
    PK76_2
    Hi @david3 !
    Your host key is visible in the Zoom web portal. Try the following steps to locate and/or edit your host key:
    How to view and customize your host key
    You can edit and enter your preferred 6-digit host key. This host key is applied to meetings you schedule.
    1. Sign in to the Zoom web portal.
    2. In the navigation menu, click Profile(Tip: You can click this hyperlink to be brought directly to your own profile)
    3. Scroll down to the Meeting section.
    4. Select the eye icon next to your Host Key to view your current 6-digit pin.
    5. Click Edit.
    6. Input the new host key desired and click Save.
    This information can also be found in the following Zoom support article: Using your host key
