Displaying Scheduled meetings date range not working | Community
  • December 30, 2025
  • 0 views
Hi, First time I have had cause to use this forum.
I'm setting up a bunch of meeting for next year and I want see them all at the same time but the "NEW" feature Display period won't allow me to set a new Date Range.
I'm unable to over type or select a new date range. The help ? mark is of no use what so ever.
Id screen shot the proplem but can't see a way to upload it here.
Stuart.
Hi Stuart, welcome to the forum.
This is a known limitation/bug with the new Meetings UI. The Display period date range field is not directly editable by typing, and in some cases the date picker does not activate as expected.
A few things you can try that often resolve it:
  1. Switch back to the classic Meetings view (if the option is available in your account settings). The date range filter works correctly there.
  2. Change the browser or open an incognito/private window, as cached UI scripts can block the date picker from opening.
  3. Disable browser extensions temporarily (especially ad blockers or script blockers), then refresh the page.
  4. Try accessing Meetings from the Zoom web portal on another device to confirm whether it’s UI-specific.
Regarding screenshots: the community usually enables image uploads only after a few interactions, so that may be why the option isn’t visible yet.
If the issue persists, it’s worth reporting it to Zoom Support as a UI regression, as the Display period filter should allow date selection via the calendar picker.
