Zoom AI Companion2023-08-15 01:52 PM
We are using Zoom Room Controls to control a QSYS Core 110f. Every 60 seconds QSYS closes the connection as described here:
Then the zoom computer instantly reconnects. In the short term things work fine, however every few days it seems, something in the network stack of the QSYS core crashes and it needs a hard reboot. I have experienced this with QSYS when there is a large volume of active sockets or high amounts of control activity. I think there may be a memory leak in QSYS's network stack, or something of that nature. Perhaps closed sockets are not getting properly deleted. Unfortunately I cannot control that.
However I was wondering if there is a way to keep the connection alive so the logs aren't flooded with a reconnect every 60 seconds from zoom and there isn't the constant disconnect/reconnect. How can I have zoom send some data to QSC Core every 55 seconds?
