2025 CMX Awards
Celebrate with us
Need Help Calendar Scheduling
DB25
Trying to have clients go to a scheduling calendar (does Zoom have this?) and sign up for a Zoom appointment. Is this possible?
1 REPLY 1
sachinzoom
Hi @DB25
Yes You can integrate your calendars and it is the preferred method of scheduling / attending meetings. Here are the steps:
https://support.zoom.us/hc/en-us/articles/360000488243-Using-calendar-and-contacts-integration
