Zoom AI Companion2023-02-08 01:39 PM
2023-02-19 09:05 AM
hi jvaughan,
you can copy and paste outside info onto a whiteboard. for some unknown reason, right click on the mouse does not work. on your whiteboard, use the ancient ctrl+v method (at the same time press the Ctrl key and the v key).
thanks,
eliot
2023-07-06 02:15 PM
This did not work for me 😞
I am having a really hard time and need this capability!
2023-07-08 07:23 AM
hi kkonzack,
please try ctrl+c or right click and copy for copy outside info and ctrl+v for paste into whiteboard.
i just tried it with Zoom windows client 5.15.2 and it works.
if it does not work for you, which of the zoom whiteboards are you using, what is the client version and what is your operating system?
thanks, eliot
