virtual background on macbook air
stanlit
why does not zoom enable virtual background without physical greenscreen on i3 intel in Macbook Air? it's been a year since macbook air with i3 was released.
6 REPLIES 6
Rupert
Creator
Hi @stanlit
The i3 is not supported for Virtual Background.
Minimum system requirements for Virtual Background on Mac require an i5 - 2 cores or higher, 6th generation or higher.
Hope this helps clarify
Rupert
how about video adding in virtual background ?
still can’t. do you know another way to add virtual background when using zoom? maybe third party app….
HI Rupert, I have these specs on my MacBook Air & it still doesn't work without a greenscreen & there is no blur option. Any idea if or when this will be updated on the zoom platform?
Hello Rupert,
Do  the current MacBook Air models allow virtual backgrounds on Zoom?
