Discover Zoom success stories and upcoming events! Explore our Customer Success Forum & Events page.
Visit NowEmpowering you to increase productivity, improve team effectiveness, and enhance skills.
Zoom AI Companion2023-02-01 10:43 AM
Hello , we have US/CAN/UK numbers registered in twillio . Is it possible to port them to zoomphone platform ?
2023-02-01 11:54 AM
Hello there,
Yes please follow this article to port your numbers to Zoom
If this helps, please accept the answer as an accepted solution.
2023-02-02 04:58 AM
Hello Sachinzoom , thanks !
So the process for porting numbers from different geos is different ? What docs are required for CAN/US and UK numbers ?
2023-02-02 09:08 AM - edited 2023-02-02 09:45 AM
Hello There,
Sure you are welcome. Please review the FAQs for more info that you are seeking. Should answer your questions.
Also, Here's info about other regions ( yes each region porting processes are different)
https://support.zoom.us/hc/en-us/sections/360007663452
https://support.zoom.us/hc/en-us/articles/360036099112
