Zoom AI Companion2023-04-18 11:41 AM
I have one of my users who's second call to her Poly VVX350 is not ringing thru when she is on the first line talking. The second calling party gets a message "Sorry, there is no one to answer your call" and I can't seem to find where or what I need to set, to allow the second call to ring thru. Appreciate any help/input.
Solved! Go to Solution.
2023-04-18 02:15 PM
Hi @Phranc
That would be the "When I'm busy on a call" option in the Zoom web portal for the User's Phone > Settings . It should be set to "Call Waiting" (see attached screenshot).
https://support.zoom.us/hc/en-us/articles/360059966372-Customizing-call-handling-settings
I hope that helps!
2023-04-18 02:15 PM
Hi @Phranc
I hope that helps!
2023-04-19 04:46 AM
Thank you so much Craig, that did the trick!
2023-04-19 08:44 AM
