Zoom AI Companion2022-11-30 09:39 AM
I have a few small remote offices using Poly VVX250 phones.
Main DID rings a call queue (we'll call Q1) that has phone 1 & phone 2, ring simultaniously. A manager at the office is at phone 3.
Is there a way for Phone 3 to "pull, pickup, transfer" the call from Q1 if the people are helping customers at the counter and unavailable to answer the call?
Thanks in advance for your help.
Solved! Go to Solution.
2022-11-30 12:16 PM - edited 2022-11-30 12:33 PM
Yes, there is a way to turn on the Call Queue Pickup Code which could be used by the Manager to answer the call.
Once it is set up, the Manager would just dial the Pickup Code to answer the incoming call. You can also set up a Line Key for he Manager's phone as a Speed Dial for the Pickup Code. Just be sure to include the preceding asterisk(*) in the Key Assignment Field.
https://support.zoom.us/hc/en-us/articles/360040587552-Customizing-line-keys-and-positions-settings
I hope that helps!
I hope that helps!
2022-11-30 01:18 PM
Thank you for the information.
I set up for one of my locations and had them test with great success. 🙂
I will look at setting up the speed dial
Thank you again.
2022-11-30 01:22 PM
You're welcome, Gus!
I'm happy that I was able to help. 😊
