You're invited to Zoomtopia 2022! Our annual user conference will take place in the Americas on November 8-9 and in APAC, Japan, and EMEA on November 17.
Learn more about our hybrid event experienceEverything you need to work together, all in one place.
Explore Zoom One's Collaboration ToolsConnect virtually from anywhere with Zoom Meetings
Collaborate together with Zoom Chat
Call the world with Zoom Phone
Create and brainstorm with Zoom Whiteboard
Rich conversation analytics to improve sales
Send and receive messages and calendar invitations
Innovative video solutions for every meeting space.
Bring meeting spaces online with Zoom Rooms
Conference Room Connector links existing rooms to Zoom
Innovative solutions for every space
Solutions to host impactful virtual and hybrid experiences.
Find a Solution for Every EventHost hybrid and virtual events with Zoom Events
Elevate your brand with single session events powered by Zoom Sessions
Broadcast at scale with Zoom Webinars
Host and attend classes, group events, and more OnZoom
An omnichannel cloud solution optimized for video.
Engage customers with Zoom Contact Center
Deliver intelligent support with conversational AI
Zoom solutions elevate collaboration across vertical use cases.
Discover Zoom Industry SolutionsEnabling exciting new ways to teach, learn, and connect globally
Transforming client engagement and employee experiences
Improving collaboration between agencies, ministries and constituents
Connecting care, collaboration, and medical innovation
Real-time communication, anywhere in the world
Bridging the in-store and online experiences
Expert support and services for all your design, strategy, implementation, event, and hardware needs.
Global Services
Flexible subscription plans for hardware
An open platform that allows developers to build Zoom apps and integrations.
Explore over 1,500 apps in Zoom App Marketplace
Documentation for building on Zoom's platform using APIs, Webhooks, and SDKs
Resources that help developers evaluate & build with our solutions
Post your questions and get help from our developer community
Zoom Partners bring Zoom's communications platform to market through alliance, sales, and service partnerships.
Explore Zoom's technology ecosystem
Find a trusted Partner
Learn about Zoom's Partner Programs
Access marketing & sales resources
Login to the Partner Portal and click 'Learn'
Discover new ways to use Zoom solutions to power your modern workforce.
Access expert-led tutorials on Zoom products and features.
Network with other Zoom users, and share your own product and industry insights.
Get documentation on deploying, managing, and using the Zoom platform.
Keep your Zoom client up to date to access the latest features.
Download CenterDownload hi-res images and animations to elevate your next Zoom meeting.
Browse Backgrounds2022-10-17 07:59 PM
My user using poly vvx250 phone set, why does a local incoming call the caller ID marked with a "+" in front of the caller ID? Normally any local calls the caller ID should not have a "+". And now the user cannot return calls based on the caller ID in the phone set call history because the caller ID starting with "+" sign is not a valid local phone number pattern. How can I remove the "+" sign in the incoming caller ID?
2022-10-17 11:02 PM - edited 2022-10-17 11:13 PM
Hi.
I think that this should be a problem with local call routing and/or number manipulation configuration.
Anyways, this should be still solvable with digitmaps built into Poly VVX phones.
Some things that may help you understand it a little better:
https://support.onsip.com/hc/en-us/articles/203706414-Polycom-Digit-Map-Dial-Plan-Prepend-Area-Code
2022-10-18 01:41 AM
Hi LK_EXN,
Thank you for your response. The "+" sign issue just happened in two out of 10 sites deployment. And all of the 10 sites are using the same Poly VVX250 phone set. Is there any setting in ZOOM portal that could manipulate the incoming caller ID with "+" sign?
2022-10-18 07:15 AM
i have two poly vvx 250 and 1 poly vvx 411 on firmware 6.4.3.5156. on the placed calls display and the missed calls display, they all have the +1 before the area code and telephone number. calls to extensions only have the extension number. i select the call i want to return and press dial to make a call. everything works.
if i try to manually dial the +1 telephone number using the vvx 250 dial pad, the call fails. i also tried the windows client which also failed to connect using the +1 telephone number. the windows client history does not include the +1 on incoming calls.
the +1 is an international standard called e 164 which identifies a global ('+') number and an area including north america ('1').
internally, telephone systems are programmed to route calls based on what telephone numbers are dialled. for example, zoom phone knows how to route calls to emergency services, extensions, local telephone numbers in the same area code, telephone numbers in different area code, telephone numbers in different country. this is called a dialplan.
there is a way for admins to change their zoom dialplan, but any changes should be coordinated with zoom support. please see company info->account settings->routing rules. attached are screen shots.
as to why two sites have the +1 and the others do not, you might check to see if the poly vvx 250 are running the same version of the firmware and if any changes were made to zoom routing rules and or poly dialplan.
thanks
eliot
2022-10-18 12:57 PM
I would talk to Zoom support about this!
2022-10-18 01:13 PM
i agree with enielsen.
thanks
eliot
