You're invited to Zoomtopia 2022! Our annual user conference will take place in the Americas on November 8-9 and in APAC, Japan, and EMEA on November 17.
Learn more about our hybrid event experienceEverything you need to work together, all in one place.
Explore Zoom One's Collaboration ToolsConnect virtually from anywhere with Zoom Meetings
Collaborate together with Zoom Chat
Call the world with Zoom Phone
Create and brainstorm with Zoom Whiteboard
Rich conversation analytics to improve sales
Send and receive messages and calendar invitations
Innovative video solutions for every meeting space.
Bring meeting spaces online with Zoom Rooms
Conference Room Connector links existing rooms to Zoom
Innovative solutions for every space
Solutions to host impactful virtual and hybrid experiences.
Find a Solution for Every EventHost hybrid and virtual events with Zoom Events
Elevate your brand with single session events powered by Zoom Sessions
Broadcast at scale with Zoom Webinars
Host and attend classes, group events, and more OnZoom
An omnichannel cloud solution optimized for video.
Engage customers with Zoom Contact Center
Deliver intelligent support with conversational AI
Zoom solutions elevate collaboration across vertical use cases.
Discover Zoom Industry SolutionsEnabling exciting new ways to teach, learn, and connect globally
Transforming client engagement and employee experiences
Improving collaboration between agencies, ministries and constituents
Connecting care, collaboration, and medical innovation
Real-time communication, anywhere in the world
Bridging the in-store and online experiences
Expert support and services for all your design, strategy, implementation, event, and hardware needs.
Global Services
Flexible subscription plans for hardware
An open platform that allows developers to build Zoom apps and integrations.
Explore over 1,500 apps in Zoom App Marketplace
Documentation for building on Zoom's platform using APIs, Webhooks, and SDKs
Resources that help developers evaluate & build with our solutions
Post your questions and get help from our developer community
Zoom Partners bring Zoom's communications platform to market through alliance, sales, and service partnerships.
Explore Zoom's technology ecosystem
Find a trusted Partner
Learn about Zoom's Partner Programs
Access marketing & sales resources
Login to the Partner Portal and click 'Learn'
Discover new ways to use Zoom solutions to power your modern workforce.
Access expert-led tutorials on Zoom products and features.
Network with other Zoom users, and share your own product and industry insights.
Get documentation on deploying, managing, and using the Zoom platform.
Keep your Zoom client up to date to access the latest features.
Download CenterDownload hi-res images and animations to elevate your next Zoom meeting.
Browse Backgrounds2023-02-08 08:05 AM
When a member of a call queue makes an outbound call is not automatically recorded even though it is enabled in call queue Policy Setiings.
Basically, we need all calls towards external numbers to be recorded, but when the user makes internal calls not to be recorded
thanks,
Solved! Go to Solution.
2023-02-10 09:11 AM
Alex changed the Outbound Caller ID of the Users to that of the Call Queue.
2023-02-08 03:08 PM
Hi @Alex_z
I'm wondering if perhaps their Outbound Caller ID is not set to that of the Call Queue, perhaps it is set to their direct phone number, or that of the Auto Receptionist.
I hope that helps!
2023-02-09 04:18 AM
Hi, thank you for your response.
I have changed the Caller ID to Queue ID but nothing changed. The only way to record outbound calls is by enabling call recording in the user level. But this means that all calls will be recorded, even the calls to internal extensions .
Any advice is very welcome.
thanks,
Alex
2023-02-10 06:54 AM
Hi @Alex_z
I understand your concern about enabling call recording at the user-level. I would submit a support request at https://support.zoom.us/hc/en-us/requests/new .
There is definitely a bug of some sort. This support article clearly states that the policy applies to inbound and outbound calls - See attached.
I hope that helps!
2023-02-10 08:36 AM
I'm wondering if it only records outbound calls if the call is an inbound call to the call queue that gets transferred elsewhere?
Since the call queue does not show up as a separate line key on agent's phone/app, outbound calls from an agent have nothing to indicate is a call queue call.
2023-02-10 09:11 AM
2023-02-10 09:30 AM
Yep, but that is only setting the caller-id to match that of the call queue (and only for calls to the PSTN, not outbound internal calls). I haven't seen anything that indicates changing the caller-id causes the call to be treated as originating from the call queue instead of the user's extension but have not done much investigation on this. So I could be wrong. But that would mean that only calls to the PSTN would be considered outbound call queue calls and not outbound calls to internal numbers!
2023-02-10 09:39 AM
I understand your concern, it was the only link that I could think of to let the system know that the Outbound Call is coming from the Call Queue. The Support Article clearly states though that it would record Outbound calls (see the links on reply below). I believe that it should be investigated by engineering as a bug.
2023-02-13 04:04 AM
Dear team,
Thank you all for your replies. I really appreciate it.
I found the reason for the issue.
All incoming calls are routed to the Auto Receptionist and then to the Main IVR select the department by pressing the relative key.
Afterward, the call is routed to the specific call queue.
The client wants all outbound calls to have the AR’s caller ID so all incoming calls can be routed to the Main IVR.
So, when the agent makes outbound calls are not recorded because they get the caller id of the Auto Receptionist.
Is it possible to make outbound calls with the caller id of the Auto Receptionist but also to be able to be recorded?
Thank you for your opinions
Alex
