Blocking phone calls during meeting
nyartmodel
Hello using an IPhone SE, how do you block incoming phone calls from interrupting a meeting?
1 ACCEPTED SOLUTION
FORE-Craig
Hi NYArtModel,
With the latest version of operating system for iPhone, you can use the Focus setting. You would turn on Focus before you start or join the Zoom meeting and turn it off after the meeting. You can even create one specifically just for meetings.
The following page on Apple's website describes how to use it:
https://support.apple.com/en-us/HT212608
I hope that helps!
Craig
11 REPLIES 11
FORE-Craig
Hi NYArtModel,
Are you talking about your Zoom Phone Subscription number interrupting your Zoom Meeting, or your iPhone's cell number interrupting your Zoom Meeting?
Craig
nyartmodel
The calls that are interrupting are to my iPhone's cell number.  How can I block these calls so that the meeting is not interrupted?
FORE-Craig
Hi NYArtModel,
I hope that helps!
Craig
Hi, thanks I tried this yesterday and it seemed to work fine.  Thank you!
FORE-Craig
Hi!
You’re welcome! If you would, please mark my previous message as the Solution, so that others with the same question know what to do. 😊 Thank you!
Craig
AhmedYounis
Hello, i have the same issue with Android, Samsung phone, yet it doesn't do the same for other meeting Apps, while using zoom and getting a phone call the zoom mutes sound and mic automatically so i even can't hear the other participants at all. In other apps i could just mute the phone call and continue in the meeting. Also if i am wearing a Bluetooth headset the zoom sound settings gets missed up after the call ends and the headset option disappears and only the loudspeaker settings of the phone works.
FORE-Craig
Hi @AhmedYounis
Are you talking about calls that are made directly to your cell phone, or calls that are made to your Zoom Phone number and or a Zoom Phone Call Queue?
Craig
Hi, i meant my cell phone calls.
FORE-Craig
Hi @AhmedYounis
The best way to handle that is by setting your cell phone to a "Do not disturb" or "Focus" mode when you start a Zoom Meeting. Depending on the model of cell phone that you have, this might be called different things.
I hope that helps!
Craig
@FORE-Craig wrote:
Hi @AhmedYounis
I hope that helps!
Unfortunately that will not work, phone can't be disabled while in focus mode in my samsung A71 and i believe in any other android too. The thing is that this issue is only in Zoom, i don't face it in google meet or Microsoft teams.
FORE-Craig
Hi @AhmedYounis
I would encourage you to submit this idea within the feedback form: https://zoom.us/feed. Be sure to explain clearly what is happening, and the fact that it doesn't occur with Google Meet and Microsoft Teams, which might help get it some priority! 😊
I hope that helps!
Craig
