Zoom AI Companion2023-03-01 01:08 AM
when I invite a participant - they are unable to hear me - although I can hear them clearly
2023-06-17 03:28 PM
Did you manage to get sound from participant . I have the same problem trying to solve this problem. Thank You Joanne
2023-07-10 11:37 PM
Why can't my participants hear me on Zoom?
Increase the volume on your mobile device using the volume buttons or notification panel. Even if the speaker is turned on in Zoom, your device's volume might be set to mute or vibrate only. Try using earphones or a headset with a built-in microphone. Restart your mobile device.
Regards,
Diana
