Zoom AI Companion2022-01-08 11:18 AM
I've reinstalled multiple times, checked all permissions to on, firewall is off, I downloaded the newest M1 version of Zoom. If I try to join a meeting or try to sign in it says "cannot connect check network". My internet is working perfectly.
Any ideas how to fix this?
2022-01-19 09:07 AM
Hey @Mazha, is the error you're prompt is there any specific error code with the 'cannot connect check network' error?
2022-03-23 03:10 AM - edited 2022-03-23 03:21 AM
I do have the very same problem with my Zoom Client (Application for Macbook). Zoom only tells you that you do not have a connection to the internet without error code, which makes the problem hard to locate. My Internet is working also perfectly fine and reinstalled the application several times.
I do use my Google Mail (@gmail.com) by using the address and the Zoom password and not click on the Gmail Button. If I do so then I get the code 5003.
Unfortunately, Zoom on my Safari Browser always has a disturbed audio output - sounds like some broken radio on the voices, but still understandable.
Due to these problems, using Zoom is really not preferred at the moment. So please let us find a solution.
Thanks for help!
2022-03-25 07:44 AM
Did you ever get zoom to connect?
2022-03-25 07:50 AM
In the past, yes, but since a few months this problem has appeared. I also have got a new MacBook Air in January, I guess it is since then.
I just used the Safari Browser again and it seemed fine this time. It could be that I used the Google Chrome Browser before (in contrast to what I have written initially). So maybe try this for now?
Greetings
Marc
2022-03-25 07:45 AM
I have the same problem. This happens every 6 months or so for the past 2 years. Would like to have this corrected.
2022-03-25 07:44 AM
