Discover Zoom success stories and upcoming events! Explore our Customer Success Forum & Events page.
Visit NowEmpowering you to increase productivity, improve team effectiveness, and enhance skills.
Zoom AI Companion2021-12-05 08:51 PM
I cannot get Zoom to connect on my Mac. I can use my older Mac, on wifi, but not the one I want to use (wired LAN). I get the message "You are unable to connect to Zoom. Please check your network connection and try again." I can use Skype or Google Meet, but not Zoom. Any suggestions?
2021-12-05 10:10 PM
Hi, @DrTs
Please check this:
Processor and RAM requirements
Minimum Recommended
Processor | Single-core 1Ghz or higher | Dual-core 2Ghz or higher (Intel i3/i5/i7 or AMD equivalent) |
RAM | N/A | 4 Gb |
Notes:
The bandwidth used by Zoom will be optimized for the best experience based on the participant‘s’ network. It will automatically adjust for 3G, WiFi, or wired environments.
Recommended bandwidth for meetings and webinar panelists:
Recommended bandwidth for webinar attendees:
https://support.zoom.us/hc/en-us/articles/201362023-Zoom-system-requirements-Windows-macOS-Linux
Cheers!
