Zoom meeting laptop audio problem--voice ok but trying to hear a chime---nothing
ruachpikzub
I recently bought a computer and my old computer (On a zoom meeting) would be able to
pick up the sound of my guitar and a singing bowl.   The new computer does not.  I have gone into settings
and have chosen the option under audio profile and chosen original sound for musician and "X" high fidelity and I tried also  choosing Stereo audio.  I left echo cancelled unchecked.   Every time I test, I just get my voice and not the musical instrument or chime.
I have also left unchecked  automatically adjust volume.
Any suggestions
6 REPLIES 6
RachelGomez123
Participant
Tips to troubleshoot audio issues
Check if the microphone, speakers, or headphones are plugged in and not muted.
Unplug the device, then plug it back in.
If it's a bluetooth device, ensure that it is turned on and connected properly.
Make sure that you are using a supported USB device for Zoom.
Regards,
Rachel Gomez
Thanks Rachel but this is not any of that.  I am sitting in a room with an external blue tooth speaker playing music right next to me and talking.  My voice is heard but the music is completely cancelled out.  I have set the audio to account for musicians, put it in high fidelity, stereo, etc.  You can hear my voice clear as a bell but no music at all.
MariaO
I am having the same problem.  I conduct zoom workout classes and my students can hear my voice but not the accompanying music I play.
ruachpikzub
I tried uninstalling zoom but the problem remains......so frustrating because I want to support my church by providing music
mBriathra
I'm having the problem of other users hearing voice but not instrument (if I'm using the internal speakers) on my MacBook Pro laptop. Using interface (Scarlett 212) it's ok unless I play a whistle (tenor D) to the mic. Then it cant be heard. Only voice.
Hi2023
Same here.
