What's New at Zoom? Join our upcoming webinar to get you a first-hand look into some of our exciting new product and feature releases.
Register Now
ZOOM has problem : Breakout room
PR_surawiwat
Ask Question ?
zoom lincese Type 300 and 500
How many breakout rooms can be maximum?
 There was a problem with the Break out room, stuck during use.
causing the need to close the program and reopen it
3 ACCEPTED SOLUTIONS
opbluelegend
Attendee
You can create up to 50 breakout rooms. The maximum number of participants in a single breakout room depends on the meeting capacity, number of breakout rooms created, and if participants are assigned during the meeting or before the meeting.
opbluelegend
Attendee
50 breakout rooms are maximum capacity
opbluelegend
Attendee
Up to 200 participants can be pre-assigned to breakout rooms. *The maximum capacities listed require a Large Meeting add-on.
8 REPLIES 8
opbluelegend
Attendee
Thanks for the previous advice.
I have an inquiry
Zoom type 300 can create up  breakout rooms ?
Zoom type 500 (add-on) can create up  breakout rooms ?
How many help can there be? (co-host)
How many meeting participants can be taken into separate  Breakout rooms per room?
I have a meeting capacity of 500 participants and I need to divide all the participants in to 50 groups ( 10 in each group) or a different number of participants in each group - can I do it? Please reply urgently. Thank you
opbluelegend
Attendee
opbluelegend
Attendee
thank you very much
opbluelegend
Attendee
accept as a solution please my 3 replys
opbluelegend
Attendee
thanks you🙂
