Uploaded Virtual Background Poor and Pixelated Quality
LindsMary
I'm having a few issues with the quality of an uploaded virtual background. I have double-checked that I meet the system requirements, tried the suggested dimensions, and ensured a high-quality download. But regardless of this, the background appears blurry and pixelated. Has anyone else experienced this or does anyone have any improvement suggestions?
5 REPLIES 5
AaronO
Attendee
Hi LindsMary,
What are you system specs? It may be, if you are just barely meeting the system specifications, it won't be the highest quality. Can you send a screenshot of the bad quality virtual background? Make sure to only screenshot the section of the screen that doesn't show you or anyone else.
Is your image size 1920x1080? You may also try adjusting your display settings to a different resolution to see if that fixes the issue.
LindsMary
Hi Aaron, thank you for the response. I have attached the specs as well as the screenshot.  The image is 1920x1080, yes.
Samtsull
Hi! @LindsMary were you able to resolve this? I'm having the same issue. The rest of my background image seems fine but the logo is very pixelated. I'm a graphic designer, so I know the logo is linked properly and the resolution is correct. The jpg image I uploaded is not pixelated so Zoom is doing something to the image.
domenicadh
Hi @Samtsull were you able to resolve this? I'm having the exact same issue.
Samtsull
@domenicadh Nope 😕 Would love some help here!
