Zoom AI Companion2022-03-06 02:54 PM
Hi everyone,
i’m using a setup with two Oktava 012s and a Motu M2 audio interface. I use this set up to get higher audio quality for music. The set up sounds fine on my DAW, but when I try to use it in a zoom meeting, it sounds very static-y and poppy. This set up worked fine on zoom as recently as a couple months ago. My onboard laptop mic works fine in zoom meetings. I have a good connection, zoom is fully updated, and I’ve done every troubleshooting step offered on Motu‘s web site.
any ideas what could be causing these audio quality problems?
thanks!
2022-03-07 09:03 AM
Hi Joseph,
There is a setting that may help. Under Audio settings you'll see Show in-meeting option to enable "Original Sound"
More on the setting here: https://support.zoom.us/hc/en-us/articles/115003279466
2022-03-07 09:29 AM
Hello Tom,
Thanks for your reply. I tried this, as well as the other settings (high fidelity music mode, echo cancellation, and others), with no change in the popping.
2022-03-07 12:27 PM
Sorry that didn't work for you.
Are you able to try your setup on another computer to see if you have the same results?
It may be best to open a ticket with our support team.
https://support.zoom.us/ then click Contact Support
2023-03-05 11:59 AM
Sounds like the sample rates in windows and motu might not be matching/syncd. Is the symc motu to windows sample rate box checked in your motu settings?
