Zoom AI Companion2022-05-28 07:38 PM - edited 2022-05-28 07:40 PM
I use my phone for on the go lessons with my music teacher on Zoom.
When I enable Original sound on my phone, it switches to the top, noise canceling microphone and the audio from the top mic becomes so faint that it is completely unusable.
Turning original sound off cancels out my singing voice.
I was wondering if there where any developers who could make the bottom microphone the primary for using original sound.
Until a fix is made to this, I'm pretty much out of luck.
2022-05-29 11:59 PM
Hi @Skyman2002
Thanks for your contribution to Zoom Community.
I always recommend using Windows or Mac for the musician and singer.
"Original Sound" can be configured in various ways. Have you tried adjusting these to see if any give a better result?
I'd certainly suggest Hi-Fidelity and Stereo for sure. See below
If you are on Windows - you can also go into Advanced and try different audio processing methods.
