Original Sound not detecting instrument audio 5.13.3
Hi2023
Hi Zoom Community,
I've been using Zoom for clarinet lessons with my old laptop for almost 2 years, never had any problem with original sound. Teacher has always been able to hear me playing.
However, recently bought a new laptop and installed 5.13.3 then problem occurred. With screenshot of setting attached, Zoom is not able to record instrument audio as well as vocal audio completely. It either records part of it or not at all, however Zoom can record a full conversation without any issues.
Have tried changing the selections in Advanced setting, but neither works.
Can someone please help me out? Thank you.
11 REPLIES 11
hi 2023,
on the top left of your zoom meeting screen, have you toggled original sounds for musicians from 'Off' to 'On'?
Hi2023
Hi Eliot,
Yes I have enabled Original Sound for Musicians, but can't hear me singing or playing, only talking can be heard.
ZoomTestKitchen
All  your Zoom settings look correct, which makes me think that your new laptop may have some audio processing software preloaded on it that is running behind the scenes. I would recommend taking a look at Windows Task Manager -> Startup Tab to see if any of the apps/services that auto-start jump-out as the culprit. If you think you find it, then right-click and disable it.
I have a very long list of these apps, and have almost all of them disabled. Most just are not essential.
If you find this information helpful, please click on "Accept as Solution".
If you have further questions, please reply, we're happy to help.
Jeff Widgren | Host of Zoom Test Kitchen
Hi Jeff, I am hoping you can help me.  When  as a guest playing guitar the others in the room hear muffled sounds to not hear me playing guitar at all. I am not tech savvy but with help I can follow instructions. I have an HP Windows 11 with intel i5, 8 gb ram, 256 ssd. Initially I used the built in microphone but hearing my guitar was inconsistent and very poor. Then a friend purchased a usb microphone which initially worked well with my voice and guitar I was told. But, as of the past few weeks the guitar playing has been muffled sounds to cutting out to none. The voice is fine.
Your suggestions will be much appreciated.
Thank you.
I think it’s an upgrade issue. Log a ticket with zoom they might look into it quicker it’s causing me serious issue for my work.
I think it’s an upgrade issue. Log a ticket with zoom they might look into it quicker it’s causing me serious issue for my job.
Hi Helen, I was able to correct the issue as I did a search on you tube and found the advice that did it. I appreciate your kind and thoughtful suggestion.
Be safe, be well, God bless you.
AndyM1
Hi I had the same problem with my new PC and playing the violin for music lessons on zoom. (It used to work OK on my old PC.)   I followed all the instructions about audio for musicans and made sure that Original sound for musican was set to On but it still didn't pick up my violin.  I then looked under the advanced tab and changed the "Signal processing By Windows audio device drivers" from auto to Off.  Zoom now picks up my violin correctly.
I hope that this works for you.
I think it’s an upgrade issue. Log a ticket with zoom.
Hi Andy, I was able to correct the issue by doing a search on you tube. The advice given did it. Thank you for your kind and thoughtful suggestion.
VPianoStudio
Based on their most recent update (see latest article related to original sound), it looks like users will need a paid account to access the original sound feature. It's not extremely clear and there are thousands of music teachers/students who are frantically searching for other options/alternatives to Zoom this month.
If this is not the case, then Zoom Support needs to clarify the update.
