Hey @AJC, so Huawei isn't actually 'supported' even though it can be installed by an APK for Android. Or should be able to access* the Google Playstore, where you could then download the Zoom App, did they go that route?
I'd also make sure the version of Zoom they're using is up to date; to participate in breakout rooms, they need to be on version 5.3.0 or higher. I don't think the Amazon Fire tablet should be having any problems, right? After updating, they can check the Android section of the KB article Participating in breakout rooms to see if their device is compatible.
Let me know what you find -- look forward to your reply! 😄
Leverage
cool features and
how to's from the
Community Center. If my reply helped, don't forget to click the
accept as solution button!
