Zoom AI Companion2022-09-19 11:07 PM - edited 2022-09-19 11:15 PM
Hello
I want to teach online and in the classroom at the same time, so I have equipment that can handle it (external audio interface - Universal Audio). This equipment is connected to speakers in the classroom so that the participants in the classroom can hear those participating over the network. My problem is that my speaker voice also comes back from the network and creates an audio loop. Is there any way to turn off my speaker voice from coming back and creating this audio loop from the ZOOM's application, so only the participants online hear my speaker voice? The participants in the room hear my voice live anyway
Thanks in advance
Jack Johansen
2022-09-20 06:46 AM - edited 2022-09-20 06:48 AM
Hi, @Livsvilja,
Echo suppression is built in to the Zoom audio system, but a relatively large room with speakers turned up enough for others in the room to hear is usually more than the echo suppression can deal with... hence the feedback you're probably experiencing.
However... your voice should not be audible from the speakers, if they are connected to the same computer/Zoom connection as your microphone. "In the production business" we call this "mix-minus"... Zoom knows that your voice on speakers will cause problems in echo cancellation. If you are hearing your voice from those speakers, either (a) the speakers are connected to a separate computer/Zoom connection and are intended to include your voice, or (b) your audio system (other than the computer) is also somehow routing your voice through the speakers.
The other possibility is that your voice isn't really what's causing the feedback... it's the attendee audio coming through the speakers, which flows back into the mic. There are a few ways to deal with this:
This is a common issue in hybrid meetings, which is why a professional onsite crew with audio switching gear carefully controls who can speak and who is heard at all times. You just need this on a smaller scale.
Try some of these things, and please come back and let us know what worked and what didn't. Sharing your experience is helpful for others who find this thread later.
2023-02-06 10:27 AM
A mix minus works well to remove the audio “loop” or feedback heard when sound reinforcement, such as audio speakers are needed in a large room with many in attendance. I am wondering if Zoom has built in any way to remove the loop without having to use a mix minus. It would be very helpful for pop up meetings where setting a mixer is time and labor intensive
