Zoom AI Companion2021-10-19 03:41 AM
I am on a Pro plan and meet the bandwidth and hardware requirements, but I never get 720p on a 1:1 call or group call. The video resolution in statistics alsways shows 640x360.
I have at least 20 Mbps uplink/downlink. My camera is 720p. I paid for pro plan but didn't know how to make sure the feature has been enabled by support on the backend. What shall I do?
Thanks
2021-10-19 04:05 AM
Hi @Jason3
It may be that even 720p for 1:1 meetings needs to be enabled by Zoom Support.
See: https://support.zoom.us/hc/en-us/articles/207347086-Group-HD
But beyond that, you will also need to:
Enable Group HD at https://zoom.us/profile/setting
Ensure "HD" is enabled in your local Video Settings, and that of your other participant (for 1:1).
For you to SEND HD, your participant will need to have you pinned (or in Speaker View) full screen in order to demand HD from your camera.
Likewise, for you to RECEIVE HD from your participant, you will need to have them pinned in full screen (or in Speaker View).
Also - for good practice, try to avoid WiFi.
Also ensure you are both using the desktop client - not web or cellphone etc.
2021-10-19 06:36 AM
I read this and followed every steps described in it before, but the resolution is still 360p. Don't know why.
DONE
DONE
DONE
DONE
DONE
And what does "needs to be enabled by Zoom Support" mean? Do I need to contact Zoom technical support or Zoom support help center? I don't get it.
2021-10-19 10:14 AM
@Jason3 wrote:I read this and followed every steps described in it before, but the resolution is still 360p. Don't know why.
DONE
DONE
DONE
DONE
DONE
Hi @Jason3 Yes, ultimately - if you have done everything else, this would be the next step.
"Additionally, Group HD video 720p for the Pro account must be enabled by Zoom Support."
