HD video and audio collaboration
Integrations and bots to use with Zoom
Full-featured, easy-to-use, engaging webinars
Enterprise cloud phone system
All-in-one platform to host virtual experiences
Connect your teams and streamline communications
Power up your conference rooms with video
APIs & SDKs to extend and enhance Zoom
Supporting a Hybrid-friendly Work Environment
Explore products and tools for seamless collaboration across office and home working spaces.
Discover new ways to use Zoom solutions to power your modern workforce.
Access expert-led tutorials on Zoom products and features.
Network with other Zoom users, and share your own product and industry insights.
Get documentation on deploying, managing, and using the Zoom platform.
Keep your Zoom client up to date to access the latest features.
Download CenterDownload hi-res images and animations to elevate your next Zoom meeting.
Browse BackgroundsDiscover new ways to use Zoom solutions to power your modern workforce.
Browse BackgroundsReady to set up and use Zoom, but aren't sure where to start? Begin with our onboarding support experience for everything you need to get started.
Get Started2021-11-10 04:20 AM
HI, I am new to Zoom and have a meeting tonight. I did a test run signing in today and noticed that the video/camera has me showing upside down and there is no volume even though it is unmuted?
Zoom help said to click on Profile photo at top right hand of page and select settings, when I do this there is no option for settings??!!!
Can anyone kindly help?
Solved! Go to Solution.
2021-11-10 06:06 AM
Hi Chris, you have been a star!!! at least I know now the issue is with my laptop and not a Zoom issue.
YES, a new laptop is needed, I was sold a real duff!!! I'll try and do Zoom tonight on my mobile.
Thanks so much for your help, much appreciated : )
2021-11-10 04:53 AM
Are you clicking on your profile pic in the APP on in the web portal?
2021-11-10 05:03 AM
HI Chris, not very clued up on computer terminology so bare with me. I am using a laptop I logged onto Zoom using Firefox and went to top right hand corner where it says profile and clicked on it, the only option it gave me was to sign out, there was no settings option?
2021-11-10 05:05 AM
Ah, yeah you are using a browser-based version (web portal) versus the Zoom App, and the instructions they gave you were for the APP. Are you using the built in camera on your laptop or a USB camera?
2021-11-10 05:13 AM
I'm using camera on laptop
2021-11-10 05:14 AM
Sorry built in camera
2021-11-10 05:11 AM
Does your camera appear upside down in any other applications? Hangouts, Teams, the built-in camera App, etc.
2021-11-10 05:19 AM
Haven't got any applications that I'm aware of, how can I test this?
2021-11-10 05:23 AM
Windows 10 has a built-in camera app you can simply search "camera" in the taskbar search area and it should appear. I would suggest that you start with making sure your Camera driver is up to date.
Right-click on the start menu.
Select "Device Manager" from the list
Find your "Integrated Camera" in the list of devices.
Right-click the camera and select "Update Driver"
In the pop-up window select "Search automatically for drivers"
2021-11-10 05:29 AM
I have checked and problem is with camera as upside down without using zoom, however I have already done what you suggest which is to update driver but says it is up to date. Can I download a free camera driver from somewhere, is that possible?
2021-11-10 05:31 AM
Has this issue just started recently or is has it always been a problem?
2021-11-10 05:34 AM
I don't know, as this is a 2nd hand laptop I bought about a year ago but haven't needed to use camera until today , so only just noticed I have a problem
2021-11-10 05:35 AM
Can you provide the make and model of the laptop?
2021-11-10 05:38 AM
Asus X70E
2021-11-10 05:40 AM
It is quite an old model and runs on Windows Vista
2021-11-10 05:48 AM
Oof that may be the problem :). Ok, let's try doing a driver roll back to see if that fixes the issue.
Right-click on the camera and select "Properties"
In the properties dialog window select the "driver" tab
Then select "Rollback Driver" and accept any prompts/warnings that may appear.
2021-11-10 05:53 AM
Hi, done as instructed found the Roll Back but it is greyed out and wont let me click on it
2021-11-10 05:56 AM
There is the option right above it that says Update Driver, I have done this already through a different means but think should give it a go again?
2021-11-10 05:57 AM
Ok, that means it has never been updated so there is no older driver to roll back to. If you go this site https://www.asusdriversdownload.com/asus-drivers/asus-x70e-notebook there are two different camera manufacturer drivers list for Windows Vista 32 bit. You can try install both, the one that does not match your camera will just error out during install and should not cause any issues. If this does not fix the problem I would suggest purchasing either a cheap USB camera to use or a new laptop (please go this route as Vista is no longer supported and severely vulnerable OS because of it).
2021-11-10 06:06 AM
