Bluetooth Sound Volume impact on Share Screen Sound Volume of Participants
YosYang
I got problem while sharing video while I am using bluetooth headset.
The volume on participant side will follow my computer volume.
Which mean my sound volume impact participant side.
While I am sharing video while using speaker or 3.5 mm jack headset, participant side will NOT follow my sound volume.
If I manage the sound hi/low/mute, the participant side will not notice at all.
What setting do I need to change, so bluetooth headset do not interfere sound volume of participant side?
1 REPLY 1
YaBoiB
 The participant sound volume is controlled by the participant. The only volume that you can control is that of your own machine and the "share computer sound" while screensharing a video just picks up the audio of the video that you are sharing. Not the volume scale of the computer share from your device.
I hope that this is helpful and apologize for the delay in getting back to you.
Kind Regards,
Brandon
If this response was helpful for you, please do not forget to click on the accepted solutions button!
