Discover Zoom success stories and upcoming events! Explore our Customer Success Forum & Events page.
Visit NowEmpowering you to increase productivity, improve team effectiveness, and enhance skills.
Zoom AI Companion2022-03-24 05:10 AM
Hey, I'm a bit lost.
I want to do a webinar and bought a webinar plan to do this.
Now I've done some testing. But no matter what I'm trying the video resolution that I'm sending is just 640x360.
Of course I activated "HD" in the Client Video Settings and I also activated Group HD in my Zoom Settings.
How can I achieve a better video resolution? 640x360 is totally unacceptable for me. Thought a webinar would always be in at least 1280x720?
I've already seen Zoom webinars that have definitely been in HD and had a much better quality than my attempts. 😞
Looking forward for a solution or some hints.
Kind regards
Solved! Go to Solution.
2022-03-25 01:52 AM
You need to request from ZOOM to enable this on their backend if you don't see it. Also if you have webinar you need to request they enable HD for attendees!
2022-03-25 02:34 AM - edited 2022-03-25 02:39 AM
in the browser log into zoom and click on the bottom right blue support button. Just ask them to enble it. Once enabled you need to test that it was actually enabled. You are also invited join my fb group for zoom events (if you need something beyond webinars) https://www.facebook.com/groups/zoomeventpros
If this was helpful pls make Accept as solution.
2022-03-24 08:50 AM
Below are guidelines on how to achieve HD when in a meeting or webinar.
In order to send HD:
Full-screen mode of the meeting window.
HD enabled in client settings in the Video section.
Meet our bandwidth requirements.
At least one participant must be in full-screen mode.
In order to receive HD:
2023-03-10 08:14 AM - edited 2023-03-10 08:59 AM
Hi @IP-Man, I have a Pro account and followed the guideline to activate the HD resolution. The recording quality is 1280x720 for the gallery view, but it's 640x360 for the speaker view. How can I get a higher quality for both recordings? Thank you for the help!
2022-03-25 01:43 AM
Hey,
thanks for this guidelines. I just tried out to follow them exactly but it did not change my video resolution.
And I am on a 200/50 MBit Network - so bandwith should not be a problem at all.
What else can I do?
Kind regards
2022-03-25 01:52 AM
2022-03-25 02:32 AM
Oh okay - thank you. Where can I request this?
2022-12-02 03:35 AM
fixed?????
