Power Point as Virtual Background HELP
MSTT
Observer
I started using this new feature in zoom and was very happy about it. Now when I tried using it today it is not working anymore. I can have the regular virtual backgrounds, but the PowerPoint as a virtual background is not working again. What went wrong.
2 REPLIES 2
arman_n
Hi MSTT,
What version are you currently using? Did you try to update your Zoom client app?
Latest versions of the app can usually fix previous errors/bugs if there are any.
I checked and it said that I have the latest version.  The thing is it worked before now its not.
