moving cloud recordings to dropbox? | Community
  • August 19, 2021
  • 8 replies
  • 22 views
How do I move my recordings from Zoom cloud storage to my Dropbox?
    Hey @jamey, great question! This KB article from Dropbox might help you, "Automatically copy Zoom cloud recordings to Dropbox"
    To save you some reading and clicks 😄
    To automatically copy Zoom cloud recordings to Dropbox:
    1. Sign in to dropbox.com.
    2. Click your avatar (profile picture or face icon) in the upper-right corner.
    3. Click Settings.
    4. Click the Connected apps tab.
    5. Click Zoom.
    6. Click Edit settings for Zoom.
    7. Check the box next to Copy Zoom cloud recordings to Dropbox.
    8. Click Update.
    Just take note of what copies and what doesn't copy! Hope this helps!
    How do you MANUALLY copy the zoom recordings please?
    From deeper research I see that recordings made to cloud BEFORE connecting zoom to dropbox are not copied.
    So I guess they need to be done manually?
    Friends, Has anyone identified a way to move/transfer recordings in zoom, that were made prior to connecting zoom and dropbox? Or is it our understanding that it need to be manually downloaded from zoom and then manually uploaded to dropbox?
    Thanks in advance.
    September 2, 2022
    Hey, everyone!  I see that this thread still has an outstanding question of "how to manually copy Zoom Cloud recordings".
    First, here's the Zoom Support article that has some details... some of it technical, but worth looking at:
    https://support.zoom.us/hc/en-us/articles/205347605-Managing-and-sharing-cloud-recordings
    Downloading Zoom Cloud Recordings to your computer is pretty easy:
    • Log on to your account at https://zoom.us from your browser
    • View your recordings, either from the Personal -> Recordings tabs, or this link: https://zoom.us/recording
    • Locate the "Topic" of the Meeting or Webinar you want to download.
    • Click the ellipsis ... menu button.
    • Click the Download item in the menu that appear.
    • All files will be downloaded to your device.  The location where these end up are dependent on your browser; once downloaded, you can move them to wherever you like.  If you want them to be uploaded to your cloud service, move it to your cloud service's local folder on your device, and let your cloud service do the work of moving it to the cloud.
    Has anyone found a way to automate the moving of old zoom recordings to Dropbox or any other cloud platform?
    Downloading and uploading 4TB of recordings is not an appropriate way to do this thing.
    March 28, 2023
    Welcome to the Zoom Community, @AllSafeIT.
    See this DropBox hero article for information:
    https://help.dropbox.com/integrations/zooml
    Unfortunately, it mentions this:
    Dropbox will not copy:
    • Meetings that you only attended and did not create and host
    • Meetings that were recorded prior to enabling the setting in Dropbox
    • Local recordings in Zoom
    I have used the DropBox to Zoom copy integration for over a year – I like it, but it won’t copy the separate audio files.
    Is there a way that I can mass download a number of files to my PC or, better yet, to a folder that is synced with Dropbox? It would be great to be able to do this manually without having to select every. single. file. TIA
    June 27, 2023
    @BobF, there is a DropBox integration that will copy all future Cloud Recordings to DropBox (I use this - it works well).  There's no way to do so with historical recordings within Zoom.  (The only ways I can suggest outside of Zoom is with custom software accessing Zoom APIs, or possibly something using Zapier.)
    It appears that Dropbox has dropped the Zoom integration. Any way to make Zoom push the recordings to Dropbox as a "Cloud Recording" location?
    March 6, 2024
    Welcome to the Zoom Community, @jwallace913 .
    Mine works – just tested it. Drop and re-establish your connection from Dropbox to Zoom. See this Dropbox support article:
    https://www.dropbox.com/apps/zoom
    Thanks much. That did seem to work. I was not able to find the Zoom app in Dropbox. Oddly, when I reached out to Dropbox, this is what they said to me:
    " According to your request, you’d like to look into why you are unable to locate Zoom as a connected app.
    After careful consideration and evaluation, the Zoom integration within Dropbox is being deprecated. This means that the Zoom integration will no longer be available to our customers.
    We understand that this integration has been valuable to many of our users, and we apologize for any inconvenience this may cause. However, we believe that focusing our efforts on other features and integrations will allow us to provide an even better experience for our users."
    I hope they don't kill this connection.....
    March 8, 2024
    Wow, @jwallace913.  That’s very interesting. I had no idea they were really killing it.
    I’ve been investigating development of a marketplace app that would connect to Zoom and manage interfaces to a variety of Cloud Storage services, and do a better job of offline managing Zoom Cloud Recordings in general. Looks like there might be a window of opportunity here for a paid service.
    Sadly, my Dropbox on my hard drive doesn't pull the recordings down from Dropbox any longer. Why they broke what wasn't broken, I'll never understand. It worked great and now they've stopped it from working. Shaking my head. 😮
